Converting Autocad 3D components to .stp files
baliasM74U3
baliasM74U3
Hi Experts
I have lot of Autocad 3D blocks, from an old system. How can i convert them into a format that is compatable to open in Inventor.
Basil
Gabriel_Watson
Try in Inventor (as long as you have Autodesk DWG TrueView also installed): Open > select AutoCAD DWG format > Options > Import > Open > checkmark "3d solids" option in the import wizard.
https://youtu.be/Ua9bBFe6dF4
Here are a couple of other methods involving translations (export then import):
https://resources.imaginit.com/manufacturing/getting-autocad-3d-files-to-inventor
johnsonshiue
Hi Basil,
Other than importing the dwg file, a few options you may try. 1) Use ACISOUT to export it as SAT in AutoCAD. 2) Use STEPOUT to export as STEP. Then import it to Inventor accordingly.
Many thanks!
Software Test Engineer
