Pattern on flat pattern
baliasM74U3
baliasM74U3
Hi Experts
How can I give this kind of a pattern on a piece of flat sheet in Inventor ?
blandb
Are you wanting just a representation, or are you actually wanting the pattern extruded on the piece?
Autodesk Certified Professional
baliasM74U3
Just a representation
BDCollett
There is an appearance called "Diamond plate" for this.
baliasM74U3
How can I apply this ?
blandb
When you have your part, just select the face > go to appearance drop down and choose Diamond Plate:
BDCollett
As blanb said, you can override the appearance with the diamond plate.
If you want to always have it applied to a material, you can create your own, call it "Aluminium Tread Plate" or something and then apply that appearance to it.
