- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good Morning
I have recieved a STL file and am trying to convert it into a solid so i can edit the faces.
It is a Impeller design and i am looking at removing the blades and replacing with Clear acrylic blades.
I need to still print the base of the part because it has a complex spiral design that unfortunatly i cant machine.
Also i am unable to share the file because of confidentuality issue so i am aware this makes my request even more difficult.
I have opened the file and converted to Base feature, and the warining staes the mesh feature has more than 5000 triangles which may fail to convert.
It does this ok but i am left with over 350 errors which upon selecting each one wont repair.
Is there anything i can do before i convert it to a base feature that will help.
I have downloaded Mesh mixer to try and repair the STL file but this doesnt seem to work either.
Be greatfull for any tips.
The person who gave me the file only has access to the STL file.
