converting a step file with invetor's features
Hey, Im wondering is this possible to adapt a step file in to ipt with inventor's features?
I mean, like in solid works, when you can change a dumb solid in to a model which is calculated by solid into similar thing by doing solid's features, after this u are getting your model with a design history
can we do it?
Cadmanto
What you are looking for in Solidworks was called "Featureworks".
In Inventor they have an add on called feature recognition.
See this link.
https://forums.autodesk.com/t5/inventor-forum/inventor-2017-feature-recognition-not-asking-to-recogn...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
swalton
Autodesk has a subscription app that should do feature recognition: https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=9172877436288348979&appLang=en&os=Win32_64
I've never used it, so I don't know if it will work in your case.
Otherwise, I'd use the direct editing tools, or model from scratch.
Steve Walton
Inventor 2025
Vault Professional 2025
thanks guys!  I was looking for excatly sth like this
