- Mute
- Permalink
- Report
I need to create slots in conical shape model. I have used sculpt command to transfer the intersecting part 3d contour into conic part and as intersecting part does not protrude conical part, then further on I have used thicken command to create penetrating cutout.
As created feature has complex 3d shape (profile of intersecting part has a radius and material cutout is done in conical part) , then creating flat pattern the cutouts are not perpendicular with flat pattern surface (attached picture).
Please advise what workflow is suitable for achieving perpendicularity. Further on it needs to be adoptable with parametric design so probably plain sketch creating solution would not help.
PS Somehow when using delete face command for cotuot adapting the ability of part to be flattend disapears.
