Dynamic simulation of spherical mechanisms
shashank.sharmaXY9H6
Message 1 of 11
Hey all. I'm trying to simulate a four bar spherical linkage. It is working alright in the assembly mode i.e. dragging the links moves the mechanism in predictable ways. However, when I go to the Dynamic simulation environment, the mechanism is always overconstrained. I'm at a loss on how to apply all the constraints so that it animates. I've tried revolute joint, spherical joint, point-line joint, etc but unsuccessful. Can some please guide me? Thanks.
Replies (10)
Message 2 of 11
WHolzwarth
IAM is not enough, attach your IPTs, too. Best way is zipping them all into one file.
Walter Holzwarth
Message 3 of 11
Hey! I've included the .ipt and .iam together in a zip file. Please have a look.
Message 4 of 11
zip files
Message 5 of 11
Still haven't found a solution. Anyone has any ideas?
Message 6 of 11
JDMather
See Attached.
Message 7 of 11
JDMather
Where did you go?  I was going to recommend you for a job opportunity.
Message 8 of 11
Hey JDMather,
Your solution works perfectly. Its really interesting how you constrained each degree-of-freedom to fully constrain a spherical mechanism even though its actually an over-constrained spatial mechanism according to Chebychev–Grübler–Kutzbach criterion. Thank You! Do let me know about the opportunity you had in mind.
For others who might be interested in simulating a spherical four-bar, use the following mating/constraining strategy:
(Assuming fixed base link)
Constraint 1: Spherical constraint between base and input link. (-3 mobility for input link)
Constraint 2: (Fixed Pivot 1) point-axis constraint between base and input link. (-2 mobility for input link)
Constraint 3: Spherical constraint between base and output link. (-3 for output link)
Constraint 4: (Fixed Pivot 2) point-axis constraint between base and output link. (-2 mobility for output link)
Constraint 5: (Moving Pivot 1) axis-axis constraint between input and coupler link. (-4 mobility for coupler)
Constraint 6: (Moving Pivot 2) point-point constraint between output and coupler link. (-2 mobility for coupler, -1 for output link)
If it doesn't work out the first time focus on the last constraint. Don't imposing spherical constraint between base-coupler link because it will make the mechanism over-constrained.
Message 9 of 11
JDMather
The position has been filled a couple of weeks ago.
This looks like an interesting mechanism - you have a picture of the full real-world mechanism that you can share?  What is the purpose of the mechanism?
Message 10 of 11
I'm exploring the use of spherical mechanisms in my research. They can have considerable application in origami-based folding mechanisms. Here's an article on using spherical mechanism to model a scissor door. Check it out.
https://mechanicaldesign101.com/2013/01/26/spherical-watt-i-six-bar-linkage/
Message 11 of 11
JDMather
Thanks for the link.
