Hello everyone out there.
Is there anything i can do to convert all my 2020 files to 2019 inventor file.
I used the 2020 version at home because i thought that the school used 2020 but they use 2019 and i am at my fanal exam, so i am in really in need of help.
Solved by leowarren34. Go to Solution.
Hi @Mikkel1203ERHNP,
No, you can't convert a 2020 file to a 2019 file as the versions are different (new features, etc) but if you have the 2019.4 updates installed you can open 2020 files.
@Mikkel1203ERHNP If you need to deliver an Inventor 2019 file complete with a full model browser showing all features/sketches then you will need to remodel everything in 2019 (aka start over)..
There is no way to back save Inventor files to older versions.
You can save as a neutral cad format like step files and open those models in older versions but your model browser (feature tree) will be lost as well as all sketches/constrains,etc... You can try the "feature recognition" addin to attempt to recreate a usable model browser but its still not the same as if you modeled the files in 2019..
hello everyone, i found out a solution haha, i just downloaded the 2021 version so i could use the 2020 files on the newer version. and it works fine
How does that solve the problem of your school only having 2019 again?
But whatever.. Glad you got something going..
