Message 1 of 20
05:00 AM
I want to extract a single face from a solid contained in a step file.
I have tried many ways to convert the face directly into a surface but none have worked. In SW this is so simple (you just select the face and offset the surface by a distance of 0). Seems like the best I can do is first save the STEP as a part and then use the Derive tool to import it as a surface (so horribly clumbersome), but that gives me a single surface for the eitire solid, not the surface I want and I can't delete the unwanted faces.
Is there an easier way? Is there a way to Offset in the same way as SW?
