Convert solid body from part to editable part?
Would it be possible to convert a solid body from (inside) a part into a new part, while keeping all features in the new part?
I would like to turn an existing multibody part into an assembly, in which all parts are directly editable.
Thank you!
Replies (7)
JDMather
Yes, but maybe not in the way you are familiar.
Attach your file(s) here.
Thank you, Im affraid I can't share it due to my strict NDA 😞 could you explain how you would do it?
TheCADWhisperer
@Anonymous wrote:
... could you explain how you would do it?
No, I am much better explaining with geometry rather than words.
Can't you make up a dummy file(s) that exhibits all of the behaviors of your proprietary data?
johnsonshiue
Hi! If you are a subscriber, you can download Feature Recognition app for free.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=9172877436288348979&appLang=en&os=Win64
Many thanks!
Software Test Engineer
mcgyvr
Thank you!
@Anonymous  Is your part composed of a single solid body or multi-body solids?
Are any features of that solid body based on any other features that you don't want in this new part?
Have you tried to just save copy as and delete all the features you don't want in this new part? If so what doesn't work about that?
I can't believe I didn't think of the 'save as- method' you described, thank you!!
Thank you for the support! I fixed it already 🙂
