I have a parameter with options A, B or C and if the parameter is set to either A or B then another True/False parameter should be set to False.
I've tried this
SyntaxEditor Code Snippet
If WallFront = "A" Or "B" Then FlangeFront = False Else FlangeFront = True End If
WallFront is a multi-value text parameter.
FlangeFront is a true/false parameter
but get error "Conversion from String .... to type 'Boolean' is not valid". Is this possible to do and if so what am I doing wrong?
Best,
Fredrik
Solved by Curtis_Waguespack. Go to Solution.
Hi fredrikjohan.carlsson,
Try this:
If WallFront = "A" Or WallFront = "B" Then FlangeFront = False Else FlangeFront = True End If
I hope this helps.
Curtis
