Contour Roll Cannot Use "Developed Length" Unfold Option for Simple Cylinders
petestrycharske
Advisor Advisor
petestrycharske
All,
Good afternoon!  I've run into a strange situation where I cannot utilize the "Developed Length" option for defining the size of my flat pattern, when creating a simple cylinder.  As soon as there is some other flange or bend, I can use all 4 options for defining the flat pattern.  However, for a simple cylinder, I'm forced to use the K-Factor.  Does anyone know why this is or if there's a way to use the "Developed Length" for a simple sheet metal cylinder?  Any advice would be great and I thank you in advance!  If you have any questions, please do not hesitate to contact me.  Hope all is well and have a most blessed day!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
blair
Can you post what you've done so far. Use the Rip command to create the small gap where the items will be joined/welded.
As long as you have a gap, it can be 0.001 it will work.
https://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-B30BDD38-9CF6-496E-9133-52A59CDCAEE6
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
petestrycharske
Here is a screencast of what I'm seeing on my side...
blair
I don't think they though of using the Rolled Contour for a simple cylinder or the programmers just didn't add the option. I would go with the create a solid cylinder and use the Rip command for a simple cylinder.
I've notified the moderator to forward the post on to the IV team as a possible bug/issue and see what shakes out.
Blair
Delta Tau Chi ΔΤΧ
johnsonshiue
Hi Pete and Blair,
This is actually an intended behavior. This is because, regardless of what unroll method is selected, the calculation is always done via "equivalent" K-factor. For example, the Unroll Length could determine the neutral layer, which dictates the K-factor.
For a pure cylinder, there is no need to have other methods. You can use K-factor to control the unroll length. With a given unroll length and bend angle, you can find the neutral radius. The percentage difference between the neutral radius and the inner bend radius (cylinder) is the K-factor to use.
Many thanks!
Software Test Engineer
petestrycharske
@johnsonshiue,
Good afternoon!  Sorry that it has taken me so long to get back to this.  I understand what you're saying, but I think it's more of a convenience factor.  If a user wants to model the part accurately to develop a proper flat pattern, they would have to calculate the K-Factor themselves.  It's not impossible to do so, but it just takes time.  That's the reason, I would like to have the same option of using the developed length.  Hope this makes sense and have a most blessed night!
Peace,
Pete
petestrycharske
Below is a method for calculating the required K-Factor.
