Inventor Forum
Content Center Part's User Parameter Does Not Update
23 REPLIES 23
Message 1 of 24
cadman777
1293 Views, 23 Replies
Hello All,
This is a long time problem.
Just haven't had time to sniff it out until today, and I just can't figure it out.
Maybe someone in here can help?
Here's the deal:
I created a User Library from the out-of-the-box library parts.
In this case, the parts are pipe.
I added my own User Parameters for use in the BOM/Parts List.
For example, I added "G_D_Nom" for Nominal Diameter of pipes.
When manually placing the part from the C/C all Parameters are good.
But when I use the Frame Generator, the "G_D_Nom" Parameter always defaults to the size of the first part in the Family Table.
I wouldn't mind the problem if there was a 'quick fix' in the BOM, but I have not figured out a 'quick fix' using the BOM.
Does anybody have any ideas why that happens and how to fix it?
Does anybody know a quick fix for this problem using the BOM or some other tool?
Thanx
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
23 REPLIES 23
Message 21 of 24
emanuel.c
in reply to: SharkDesign
So, what is "Suppress Link" when I right click on the category in the content center. I realize that's why I don't have "the 3 dots". The way I copied those families was to go to the default ones and right click -> copy to -> "My custom content center" But then they all have the chain link thing 🙂 Is that not the best way? To what does it link it to anyways? Thanks!
Message 22 of 24
SharkDesign
in reply to: emanuel.c
The link keeps them in sync with the default ones. Problem is, if you
change any of the cells, when you upgrade to 2023 it deletes half of your
custom stuff so it's always best to remove the link.
  Expert Elite
  Inventor Certified Professional
Message 23 of 24
emanuel.c
in reply to: cadman777
Oh, ok, thanks! It seems that if I "Save Copy As" I can choose Link or Independent. But I created them via "Copy To..." and that doesn't seem to have those options, so by default they were linked.
Message 24 of 24
emanuel.c
in reply to: blandb
Thank you for this clear explanation!
