Message 1 of 16
Contact Solver Problem
- Mute
- Permalink
- Report
Hi, im using inventor por 2023 and im trying to use the contact solver for 2 rotating parts ( i can rotate them seperatly without problems). the shaft should make the plate move when it collides. I did made a contact pair with the 2 part and if i toggle of the contact solver, they just move through each other (as supposed). If i toggle on the contact solver, there is a collision, but no resulting movement. if i try to rotate the top plate through the shaft, the shaft collides and after i drag the mouse further, i teleports through the plate collision points... any suggestions?
