Inventor Forum
Constraint
4 REPLIES 4
262 Views, 4 Replies
Constraint
You can see video sketch is full constrained. But my sketch is not. Please identify  the error.
My sketch:
Video sketch:
https://www.youtube.com/watch?v=qh1WZ6EVSuY
Time 1:05
4 REPLIES 4
mdavis22569
just an FYI ..at .1:03 ...he says ...Lets step ahead, he edited out what he was doing. He goes from 8 to 0 constraints in a sec ..
So it's hard to know exactly what he's doing. We can constrain it ourselves but I won't be the same as him
All I did was add a mid point and the arc constraint to make it fully contrained
Mike Davis
in reply to: mdavis22569
Thank you
IgorMir
You can do away with 500mm. dimension. Equal constrain (=) should be sufficient in this occasion. It will give you less entries in the Parameters list.
Cheers,
Igor.
Web: www.meqc.com.au
mdavis22569
in reply to: IgorMir
I put the .500 in so he knew that's what I was doing.   The original value he had was .649.  I didn't know if it was .500 .... however I did confirm that the 2 .500 were equal ...
Mike Davis
Technology Administrators
