Constraint bug - Inventor Pro 2022 shows wrong in top assembly
- Mute
- Permalink
- Report
Some of my colleagues have been getting this bug more frequently, and it is rather critical.
When in a top assembly, some parts are out of place, even though Design Doctor shows no bad constraints.
When going in to the assembly with the visible bug, the assembly looks fine. I've recorded an example of this.
You can clearly see that the cylinder is off axis in the top assembly, however when opening the sub-assembly, the cylinder is correctly on axis. As you can also see, Inventor does not ask to update the assembly, so to force the update, I removed a bolt, went back to the top assembly, and could then force an update, which solved the problem.
This is very critical, as I've seen this bug on aluminium profiles on railings, where our installation team on site uses the top layout to measure for adding holes etc. We are using version 2022.4.
