Constraining a part in the middle between two adjacent surfaces of the from the same parts
nathan_m_gardner
nathan_m_gardner
Am I missing something? I have two parts, and I want to constrain one part between two surfaces of the second part. Is this a bug or my lack of knowledge on Inventor 2023?
CGBenner
@nathan_m_gardner
Welcome to the forum.  Can you share some more detail on what it is you are trying to do?  Maybe share a video or some screen shots of what you are trying to do, and what issues you are seeing?
Chris Benner
Curtis_Waguespack
Hi @nathan_m_gardner
I replied to your other post before seeing this one, so there is some info there, but here is a quick video showing how we often do this in Inventor ( I know it seems odd if you come from Solidworks for instance).
In Inventor we just have to create a work plane in the part, and use it ( or an existing plane) for the constraint.
Hope this helps,
Curtis
James_Willo
Hi, you can actually do this with joints. Whilst the command is active, right click and choose 'between two faces.'
James W
Inventor UX Designer
CGBenner
@nathan_m_gardner
Hello Nathan,
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
