Hi Forum,
I have imported a 7-axis "gauge-arm" which have a physical movement and a minor measureble range (MR).
Therefore I like to constrain the endpoint of the measureing tip (Tip) to the base UCS with a distance limited by the measureable range (MR).
By this I like to move the Tip anywhere within this defined sphere given by MR
Whenever I constrain or joint by tangency, surface or centerpoints it always come up with an error.
Any help will be appreciated !
Claus
Solved by kacper.suchomski. Go to Solution.
Are you familiar with the Environments tab > Dynamic Simulation Joints?
Can you Attach your assembly here (but I will be away from my Inventor machine till next week to take a look at the assembly).
Hi
Look at this:
Kacper Suchomski
