Inventor Forum
Constrain sketch to another sketch on a perpendicular plane
7 REPLIES 7
Message 1 of 8
wfp21
870 Views, 7 Replies
I am unable to find a method to constrain two points on different sketches that are perpendicular to each other.
I want to force the centre of a rectangle (red circle) to lie on the tip of an eclipse (red dot) where each are on a different sketch and are perpendicular to each other:
Hope that makes sense. I have attached an ipt file in case.
Any suggestions appreciated.
Thanks, Will
7 REPLIES 7
Message 2 of 8
CGBenner
in reply to: wfp21
@wfp21
In Sketch1 place a work point at the top of the arc.  Save that sketch.  In Sketch3, project that point into the sketch, then use a Coincident constraint between the center of the rectangle and the projected point.  Voila.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Message 3 of 8
SBix26
in reply to: wfp21
A slight correction: you need a sketch point at the top of the ellipse (though a work point could be used, too).  I see that you already have a sketch point constrained to the ellipse, but it's unconstrained otherwise.  Project the Y-axis to Sketch1, and the sketch point to that line as well:
Now that point is firmly located at the top of the ellipse, and you can project it into the other sketch and constrain to it.
Sam B
Inventor Pro 2022.2.1 | Windows 10 Home 21H2
Message 4 of 8
CGBenner
in reply to: wfp21
@SBix26 @wfp21
You caught me.... I actually USED a sketch point, and just typed work point!  It's been a long week already.  Thank you for catching that!!
Chris Benner
Message 5 of 8
wfp21
in reply to: wfp21
Thanks for you very much for your quick replies but I am still rather confused!
How do I constrain my original sketch point in sketch 1? And then how do I project the Y-axis to Sketch1?
A screen-recording of how you solve it would be amazing.
Thanks again,
Will
Message 6 of 8
SBix26
in reply to: wfp21
  • Use the Project Geometry tool while in the sketch, then pick the Y-axis from the browser
  • Best practice is to change the projected Y-axis to construction type so it's obviously not part of the ellipse profile
  • Start the Coincident Constraint tool and pick the sketch point that is already constrained to the ellipse, then the projected Y-axis; the sketch point will change color to show that it is fully constrained.
  • In Sketch3, use the same Project Geometry tool to project that fully constrained sketch point from Sketch1
  • Use the Coincident Constraint tool to constrain the center of the rectangle to that projected point
This is all really basic stuff-- have you had any training??
Sam B
Message 7 of 8
wfp21
in reply to: SBix26
I have had a little training but was unaware of the project geometry tool.
Projecting the point on sketch1 whilst in sketch3 made it visible for a coincident constraint.
Thanks for all your help
Message 8 of 8
SBix26
in reply to: wfp21
It occurred to me later (middle of the night?) that there is no need for the sketch point or the Y-axis projection-- all that's needed is:
  • In Sketch3, use Project Geometry to project the elliptical arc from Sketch1; it projects as a line, ending at the top of the curve
  • Constrain the rectangle center to the endpoint of the projected line
  • Finished
Sorry about all the extra work instructions the first time around.
Sam B
