Inventor Forum
Connection line
3 REPLIES 3
388 Views, 3 Replies
Connection line
Hello!
How can I automatically make a connection line between the top and bottom of the part?
Best regards,
Vladimir T.
kelly.young has embedded your image for clarity.
3 REPLIES 3
jhackney1972
This is probably being caused because you are using a section depth that does not extend through the part.  This is set in the Section View dialog box when setting the view.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Этот глюк при создании чертежа деталей, полученных через мастера проектирования валов.
jhackney1972
Google Translate gave me this translation to your reply.  If you are telling me that your use Shaft design from the Inventor Design Accelerator to make your design it makes no difference.  When making the drawing section view if you use "Full" for the Section Depth it should add your missing lines.
This glitch when creating the drawing details obtained through the master of shaft design.
John Hackney
Retired
