Inventor Forum
Configurator360 Error.
6 REPLIES 6
468 Views, 6 Replies
Hello everybody.
I have a testassembly wich I want to upload to the configurator360. Hereby my problem is that I get an error message on it when I change the parameters. But it works just fine inside inventor.
Hereby the coding I used for the assembly.
It's probably the usage of shared variables or the reverences to partfiles that aren't converted properly.
Any help would be appreciated.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oDocDef As AssemblyComponentDefinition
oDocDef = oDoc.ComponentDefinition
Dim oComp As ComponentOccurrence
On Error Resume Next
'Dim excel As String = "C:/test/Map1" 'excelbestand
Dim lengte As Integer = TotalLength
 'waarde totale lengte
Dim tussen As Integer= Standard 'waarde standaard lengte tussendelen
Dim mineindlengte As Integer = Minimum
Dim tussenstukken As Integer = lengte 'totale waarde voor tussendelen
Dim tussenberekening As Double = tussen + mineindlengte
Dim A As Integer = 0 'aantal standaard lengtes
Dim B As Integer = tussenstukken 'voor overige lengte
Dim D As Integer = 1 'aantal geplaatste tussenstukken
Dim C As Integer = D + 1 'te plaatsen nummer
Dim E As String = A 'voor plaatsen flushes met variabelen
Dim G As Integer = 4 'flushnummer
Dim H As Integer = 1
'verwijderen van bijna alle componenten
For Each oComp In oDocDef.Occurrences
Dim Test As String = ("Test2:" & H)
If H = 1 Then 'deleting test2: vanaf 2
	Parameter.Quiet = True
		'MsgBox("Werkt")
	H = H + 1
Else If H > 1 Then
	Components.Delete(Test)
	H = H + 1
End If
If oComp = "Test3:1" Then 'deleting var. length
	Components.Delete("Test3:1")
End If
Next
'berekenen hoeveel standaard lengtes en welke lengte over moet zijn
Do While B >= tussenberekening
	A = A + 1
	B = B - tussen
Loop
If B = tussen Then
	A = A + 1
	B = B - tussen
End If
MsgBox(A & "x" & tussen & "+" & B)
SharedVariable("aantal") = A
SharedVariable("standaardlengte") = tussen
SharedVariable("variabelelengte") = B
'plaatsen van standaard lengtes
Do While D < A
	'MsgBox(C)
	Test2 = "C:\test\Test2.ipt"
	Components.Add("test2:" & C, Test2, position := Nothing, grounded := False, visible := True, appearance := Nothing)
	Constraints.AddFlush("Flush" & G, "Test2:" & D, "YZ PLANE", "Test2:" & C, "YZ PLANE",
                     offset := tussen, biasPoint1 := Nothing, biasPoint2 := Nothing)
	G = G + 1
	Constraints.AddFlush("Flush" & G, "Test2:" & D, "XZ PLANE", "Test2:" & C, "XZ PLANE",
                     offset := 0.0, biasPoint1 := Nothing, biasPoint2 := Nothing)
	G = G + 1
	Constraints.AddFlush("Flush" & G, "Test2:" & D, "XY PLANE", "Test2:" & C, "XY PLANE",
	G = G + 1
	D = D + 1
	C = C + 1
Loop
''MsgBox (D)
'plaatsen van variabele lengte
Do While B > 0
	Test3 = "C:\test\Test3.ipt"
	Components.Add("test3:1", Test3, position := Nothing, grounded := False, visible := True, appearance := Nothing)
	Constraints.AddFlush("Flush" & G, "Test2:" & D, "YZ PLANE", "Test3:1", "YZ PLANE",
	G = G + 1
	Constraints.AddFlush("Flush" & G, "Test2:" & D, "XZ PLANE", "Test3:1", "XZ PLANE",
	G = G + 1
	Constraints.AddFlush("Flush" & G, "Test2:" & D, "XY PLANE", "Test3:1", "XY PLANE",
	B = B - B
Loop
'Calling rules in parts
auto = iLogicVb.Automation
' Set Rule Name
Dim ruleName As String
ruleName = "update length"
' Get the active assembly.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
' Get all of the referenced docments.
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
' Iterate through the list of documents
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
	Dim rule As Object
	rule = auto.GetRule(oRefDoc, ruleName)
	If (rule Is Nothing) Then
	Else
	Dim i As Integer
	i = auto.RunRuleDirect(rule)
	End If
Next
iLogicVb.DocumentUpdate
MessageBox.Show("Test2 (blauw) representeren standaard lengtes en Test3 (Geel) een variabele lengte", "uitleg testnamen")
SharedVariable.RemoveAll()
Hello everybody.
		'MsgBox("Werkt")
	H = H + 1
Else If H > 1 Then
	H = H + 1
End If
End If
Next
	A = A + 1
	B = B - tussen
Loop
If B = tussen Then
	A = A + 1
	B = B - tussen
End If
Do While D < A
	'MsgBox(C)
	G = G + 1
	G = G + 1
	G = G + 1
	D = D + 1
	C = C + 1
Loop
''MsgBox (D)
Do While B > 0
	G = G + 1
	G = G + 1
	B = B - B
Loop
' Set Rule Name
	Dim rule As Object
	Else
	Dim i As Integer
	End If
Next
6 REPLIES 6
xingyichuan
xingyichuan
Hi Wander,
There are several iLogic known limitations for Configurator 360 design. For example, we cannot use any interactive functions, including forms and the MessageBox function, cannot use the ThisApplication object, etc.
Please check below document in detail which also include the workarounds for that.
http://help.autodesk.com/view/CFG360/ENU/?guid=GUID-96EA0CAA-73BB-42C2-94D8-73CC76791DC7
Hope this helps.
Guy Xing
Hi Wander,
Hope this helps.
Guy Xing
in reply to: xingyichuan
Is this a part of an interactive function?
Also if it isn't is there a little more help on the coding for the %temp% folder you can call in 360? Can't seem to figure it out.
xingyichuan
xingyichuan
Hi Wander,
Please try to use "ThisServer" instead of "ThisApplication".
And you can write files to the %TEMP% folder, and they persist during the session.
Could you please share the Configurator 360 designs (the url of the design) or the dataset with the iLogic which is failed to upload?
Guy Xing
Hi Wander,
Guy Xing
Here's the online link:
https://configurator360.autodesk.com/810676209937569296/szcsgs3334r4
I've updated the programming a little bit (look at place part 1). Test rule whas not in it while i uploaded the file.
Filepath's used: "C:/Test/...."
xingyichuan
xingyichuan
Hi Wander,
Thanks for sharing the dataset, and it helps to narrow down the issue.
I have resolved the limitation issues in your attached file.  There are two limitations you need to take care:
  1. Please use the 'ThisDoc' instead of  'ActiveDocument' which may caused the error => 'ActiveDocument' on type 'InventorServerClass' not found
  2. You can use the `System.IO.Path.GetTempPath()' to get the temp path in the current session, or you can use the ThisDoc.Path to get the current work directory.
Attachment is the updated dataset. Hope this helps.
BTW, In order to avoid the duplicated effort, I only update this topic. Please also help to update the below topic if the solution works for you. Thank you!
https://forums.autodesk.com/t5/configurator-360-forum/could-somebody-help-me-working-around-restrict...
Guy Xing
Hi Wander,
Guy Xing
Thank you so much.
I was out of the office so I couldn't update it much faster but it works and i will look into it a bit more to exactly understand what I did wrong.
Thank you so much.
