Hello everybody.
I have a testassembly wich I want to upload to the configurator360. Hereby my problem is that I get an error message on it when I change the parameters. But it works just fine inside inventor.
Hereby the coding I used for the assembly.
It's probably the usage of shared variables or the reverences to partfiles that aren't converted properly.
Any help would be appreciated.
Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument Dim oDocDef As AssemblyComponentDefinition oDocDef = oDoc.ComponentDefinition Dim oComp As ComponentOccurrence On Error Resume Next 'Dim excel As String = "C:/test/Map1" 'excelbestand Dim lengte As Integer = TotalLength 'waarde totale lengte Dim tussen As Integer= Standard 'waarde standaard lengte tussendelen Dim mineindlengte As Integer = Minimum Dim tussenstukken As Integer = lengte 'totale waarde voor tussendelen Dim tussenberekening As Double = tussen + mineindlengte Dim A As Integer = 0 'aantal standaard lengtes Dim B As Integer = tussenstukken 'voor overige lengte Dim D As Integer = 1 'aantal geplaatste tussenstukken Dim C As Integer = D + 1 'te plaatsen nummer Dim E As String = A 'voor plaatsen flushes met variabelen Dim G As Integer = 4 'flushnummer Dim H As Integer = 1 'verwijderen van bijna alle componenten For Each oComp In oDocDef.Occurrences Dim Test As String = ("Test2:" & H) If H = 1 Then 'deleting test2: vanaf 2 Parameter.Quiet = True 'MsgBox("Werkt") H = H + 1 Else If H > 1 Then Components.Delete(Test) H = H + 1 End If If oComp = "Test3:1" Then 'deleting var. length Components.Delete("Test3:1") End If Next 'berekenen hoeveel standaard lengtes en welke lengte over moet zijn Do While B >= tussenberekening A = A + 1 B = B - tussen Loop If B = tussen Then A = A + 1 B = B - tussen End If MsgBox(A & "x" & tussen & "+" & B) SharedVariable("aantal") = A SharedVariable("standaardlengte") = tussen SharedVariable("variabelelengte") = B 'plaatsen van standaard lengtes Do While D < A 'MsgBox(C) Parameter.Quiet = True Test2 = "C:\test\Test2.ipt" Components.Add("test2:" & C, Test2, position := Nothing, grounded := False, visible := True, appearance := Nothing) Constraints.AddFlush("Flush" & G, "Test2:" & D, "YZ PLANE", "Test2:" & C, "YZ PLANE", offset := tussen, biasPoint1 := Nothing, biasPoint2 := Nothing) G = G + 1 Constraints.AddFlush("Flush" & G, "Test2:" & D, "XZ PLANE", "Test2:" & C, "XZ PLANE", offset := 0.0, biasPoint1 := Nothing, biasPoint2 := Nothing) G = G + 1 Constraints.AddFlush("Flush" & G, "Test2:" & D, "XY PLANE", "Test2:" & C, "XY PLANE", offset := 0.0, biasPoint1 := Nothing, biasPoint2 := Nothing) G = G + 1 D = D + 1 C = C + 1 Loop ''MsgBox (D) 'plaatsen van variabele lengte Do While B > 0 Parameter.Quiet = True Test3 = "C:\test\Test3.ipt" Components.Add("test3:1", Test3, position := Nothing, grounded := False, visible := True, appearance := Nothing) Constraints.AddFlush("Flush" & G, "Test2:" & D, "YZ PLANE", "Test3:1", "YZ PLANE", offset := tussen, biasPoint1 := Nothing, biasPoint2 := Nothing) G = G + 1 Constraints.AddFlush("Flush" & G, "Test2:" & D, "XZ PLANE", "Test3:1", "XZ PLANE", offset := 0.0, biasPoint1 := Nothing, biasPoint2 := Nothing) G = G + 1 Constraints.AddFlush("Flush" & G, "Test2:" & D, "XY PLANE", "Test3:1", "XY PLANE", offset := 0.0, biasPoint1 := Nothing, biasPoint2 := Nothing) B = B - B Loop 'Calling rules in parts auto = iLogicVb.Automation ' Set Rule Name Dim ruleName As String ruleName = "update length" ' Get the active assembly. Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument ' Get all of the referenced docments. Dim oRefDocs As DocumentsEnumerator oRefDocs = oAsmDoc.AllReferencedDocuments ' Iterate through the list of documents Dim oRefDoc As Document For Each oRefDoc In oRefDocs Dim rule As Object rule = auto.GetRule(oRefDoc, ruleName) If (rule Is Nothing) Then Else Dim i As Integer i = auto.RunRuleDirect(rule) End If Next iLogicVb.DocumentUpdate MessageBox.Show("Test2 (blauw) representeren standaard lengtes en Test3 (Geel) een variabele lengte", "uitleg testnamen") SharedVariable.RemoveAll()
Solved by xingyichuan. Go to Solution.
Hi Wander,
There are several iLogic known limitations for Configurator 360 design. For example, we cannot use any interactive functions, including forms and the MessageBox function, cannot use the ThisApplication object, etc.
Please check below document in detail which also include the workarounds for that.
http://help.autodesk.com/view/CFG360/ENU/?guid=GUID-96EA0CAA-73BB-42C2-94D8-73CC76791DC7
Hope this helps.
Guy Xing
Is this a part of an interactive function?
Also if it isn't is there a little more help on the coding for the %temp% folder you can call in 360? Can't seem to figure it out.
Hi Wander,
Please try to use "ThisServer" instead of "ThisApplication".
And you can write files to the %TEMP% folder, and they persist during the session.
Could you please share the Configurator 360 designs (the url of the design) or the dataset with the iLogic which is failed to upload?
Guy Xing
Here's the online link:
https://configurator360.autodesk.com/810676209937569296/szcsgs3334r4
I've updated the programming a little bit (look at place part 1). Test rule whas not in it while i uploaded the file.
Filepath's used: "C:/Test/...."
Hi Wander,
Thanks for sharing the dataset, and it helps to narrow down the issue.
I have resolved the limitation issues in your attached file. There are two limitations you need to take care:
Attachment is the updated dataset. Hope this helps.
BTW, In order to avoid the duplicated effort, I only update this topic. Please also help to update the below topic if the solution works for you. Thank you!
Guy Xing
Thank you so much.
I was out of the office so I couldn't update it much faster but it works and i will look into it a bit more to exactly understand what I did wrong.
