Inventor Forum
Component replacement using iAssembly?
3 REPLIES 3
397 Views, 3 Replies
Hello all,
I was wondering if iAssemblies (maybe in combination with iLogic) offer the ability to dynamically replace components, being linked to members? I have an iAssembly of a roofing system containing multiple members, that could all have different sub-iAssemblies for roof covering, using different members. It would look as follows:
Main assembly member Sub iAssembly Sub iAssembly member
Front-Left-sideRooftiles.iamFront-Left-side
Front-Mid-SideRooftiles.iamFront-Mid-Side
Front-Right-SideRooftiles.iamFront-Right-Side
Back-Left-SideSolarpanels.iamBack-Left-Side
Back-Mid-SideSolarpanels.iamBack-Mid-Side
Back-Right-SideSolarpanels.iamBack-Right-Side
I've been searching the web for an hour but couldn't find any suitable solutions. Any help would be much appreciated! (I don't shy away for some coding.)
3 REPLIES 3
S_May
... please attach pictures + sketches and models + drawings (pack models by pack and go + ZIP), create patterns for sensitive data.
johnsonshiue
Hi! The workflow you are looking for is not supported. Within an iAssembly, you can use "table-replace" to switch from one iPart member or one iAssembly member to another. But, you cannot swap out any regular part or subassembly.
iPart/iAssembly is supposed to create library components. Those components have similar shape but in different sizes. All the definitions need to be captured on the author table.
If I understood your request correctly, I think you want to use iLogic instead. You can focus on building one configuration. Next you use iLogic Design Copy to preserve the variation (make a copy).  Then work on another configuration.
Many thanks!
Software Test Engineer
in reply to: johnsonshiue
Thank you, that is a good alternative!
Technology Administrators
