In Inventor 2022 there was the option to make a component patterns parts independent.
I'm using inventor 2023 and they seem to have removed this option, perhaps moved it?
Iain
Solved by johnsonshiue. Go to Solution.
Solved by SBix26. Go to Solution.
Any element of a component pattern can be made independent... except for Element:1. If you have included the component from which the pattern as made in your selection, Independent will not be available. Otherwise, it will:
This is from Inventor 2024, but 2023 should be the same.
Sam B
Inventor Pro 2024.2 | Windows 10 Home 22H2
Hi Iain,
The option is only available for the second and other pattern instances, not the first one (the source component). Please share the files that exhibit the behavior.
Many thanks!
