Hello Everyone,
I have multiple views with holes in drawing. Now I want to generate hole table for all views, thing is every table start with A1 hole tag. So is there any option to create one single hole table for all views or rearrange individual hole tag as I want. I have attached image for reference.
Milan Kantaria
kelly.young has embedded your image for clarity.
Solved by johnsonshiue. Go to Solution.
Solved by jhackney1972. Go to Solution.
I do not think this is or will be possible because of how the hole table function works. The hole table starts by placing an origin marker in each view that a hole table will be created from. Since this marker is view dependent, it is not possible have it share a common view.
You could however place your two models in the same view and indicate the location of the models to each other. This will give you a combined hole table. This method really complicate the interpretation of of the drawing so it is not recommended.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Hi! John is correct. Indeed, the kind of consolidated hole table is not available in Inventor. I guess the coordinates are not required , right? You just want a list of the holes with ID from all views without the coordinates.This sounds like a very interesting idea. Please feel free to submit it to Inventor Ideas forum (https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232).
Many thanks!
Thanks for reply.
If not combine hole table can I change hole tag for each hole table because if drawing sheet include more than one hole table, every time it start with A1 hole tag and sometimes it becomes difficult to understand.
Milan
Hi Milan,
Unfortunately, it does not look like there is an option to set default hole tag. They all start with A1. You will have to change each tag manually.
Many thanks!
There is some iLogic to renumber all the holes:
https://forums.autodesk.com/t5/inventor-forum/rename-holes-in-a-hole-tabele/td-p/5420234
it's NOT fast... but it works.
