Announcements
Tangent Constraint results vary
Vagulus
Vagulus
I have two crossmembers in my device following tracks on cam plates (see video).
As I say, the problem is to get the inner follower to go all the way around the track.
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
Marco.Takx
Hi @Vagulus,
I have to check the whole model to see what is going on.
But have you tried the Contact Set + Activate Contact Solver
2018-08-10_09-18-56.jpgIf my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Vagulus
Thanks for that but I think you replied before I completed editing the post with the video.
Here is a pack-n-go of the project to date.  Hope that helps.
Thanks again
Albert Einstein
Marco.Takx
The surface that you use to make the tangent constrain is not created from 1 spline.
Maybe this link helps you.
Place Transitional surface constraints
Marco Takx
Marco.Takx
Hi @Vagulus,
I have modified your model a little bit but it is done within Inventor 2019.1.1 release.
(See Attachment)
The problem you have is the curves are not tangent.
Marco Takx
Vagulus
That was the problem alright.  I redid the inner cam with one spline and all was spot on.
Thansk
Albert Einstein
