Inventor Forum
Combine 2 sheets with section view to another IDW file
23 REPLIES 23
Message 1 of 24
julian.cano8L4YX
1261 Views, 23 Replies
I have 2 sheets, the first with a plan view of my project and the second with a section view of sheet one, I need to copy these two sheets to combine them in another idw, but when copying and pasting it, this warning appears "Following view(s) must be copied along with their parent view(s) or view(s) they are dependent pon"  how can i copy or combine the two sheets to another idw?
Tags (1)
Labels (2)
23 REPLIES 23
Message 2 of 24
Hi
If you have a section on the sheet, it means that there is a section base outside the sheet.
I think it will be easier to move this base to the sheet area and describe it on the basis of the second sheet than to copy the views.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 3 of 24
Yes, it can be done that way, but I'm worried about the processing times because I'm working on combining many idw into one and I need to copy the base view (sheet 1) and the section view (sheet 2) I must do this many times, I would like to find a solution that is only copy and paste to reduce the times, but when I select the two sheets and copy and paste the sheet with the base view is copied normally but the sheet two with the section view is not copied and I get this warning "Following view(s) must be copied along with their parent view(s) or view(s) they are dependent on"
Message 4 of 24
is the problem, and I don't know how to fix it
Message 5 of 24
Derived views (sections) are dependent on based views. If you have a section view on a sheet, that means you have a base view on the same sheet (out of paper space but on the same sheet) that must be preserved for the section to exist.
Kacper Suchomski
Message 6 of 24
No inventor allows to have the base view on one sheet and move the section view to another sheet
Message 7 of 24
Yes
Kacper Suchomski
Message 8 of 24
Follow the instruction: copy parent and detail/section views.
Detail view need the view it was created from.
Message 9 of 24
If i select the parent and the detail/section views the option copy do not appear
Message 10 of 24
Copy both sheets and paste it new IDW.
Drag and move the section view to the other sheet in new IDW.
Message 11 of 24
It works:
Kacper Suchomski
Message 12 of 24
if i copy and paste both sheets in a new idw i get this warning "Following view(s) must be copied along with their parent view(s) or view(s) they are dependent on" the sheet with the base view copy normally but de sheet with the section view do not
Message 13 of 24
Yes. It's norma. I wrote it.
Kacper Suchomski
Message 14 of 24
no this is not what i am looking for i made a video to show what i am looking for
Message 15 of 24
You must first transfer the section to the parent plan sheet.
Kacper Suchomski
Message 16 of 24
Yes, that's what I'm doing but in some cases it's up to 40 section views of the same base reference, which makes this method very slow.
Message 17 of 24
Move the parent to the sheet with section view.
Message 18 of 24
Message 19 of 24
With different parents?
Message 20 of 24
Sometimes that's just how it is at work that you have to sit and do xD.
Kacper Suchomski
