Comando interrompi su tavola 2D - Break command on 2D table
s_ciocca
s_ciocca
Ciao,
utilizzo Inventor 2023 e mi capita sempre questa situazione.
Nella tavola 2D utilizzando il comando "INTERROMPI", le quote vengono modificate (allego video).
[Translated with Google]
I use Inventor 2023 and this situation always happens to me.
In the 2D table using the "BREAK" command, the dimensions are modified (I attach a video).
Vorrei sapere se nella versione 2025 questo problema è stato risolto oppure la situazione è rimasta uguale.
Grazie, Stefano
I would like to know if in version 2025 this problem has been solved or the situation has remained the same.
Thanks, Stefano
[@s_ciocca - Topic title and body has been translated by @CGBenner ].
kacper.suchomski
Hi
I can't check the 2025 version, but in the 2026 version they fixed it (probably too well).
(view in My Videos)
Kacper Suchomski
johnsonshiue
Hi! I suspect this is more to do with the dimension style than the Break View. I cannot seem to reproduce it on my machine. If possible, please share the files that exhibit the behavior here or send them in zip to me directly at [email protected]. I would like to understand the issue better.
Many thanks!
Software Test Engineer
s_ciocca
Ciao,
allego i files di prova.
Grazie, Stefano
kacper.suchomski
(view in My Videos)
Kacper Suchomski
