Coil Issues
Coil Issues
swlamech
Coil Issues
swlamech
Hello, I am trying to model a simple ramp cut into a piece of thick wall tubing.  Essentially, this part will be held in a CNC lathe while a live spindle mill comes in perpendicular to tube axis and cuts while traversing in or out.  When I try to create this with the coil command there's an additional angle to the surface and it's not perpendicular.
No matter what I do with the coil settings it doesn't work.
SBix26
Post your file here and I'm sure someone can help.  What version of Inventor are you using?
Sam B
Inventor Pro 2027.0.1 | Windows 11 Home 25H2
swlamech
I've uploaded the  part file. The blue cylinder is just there to represent the 3/4"Ø endmill.
swalton
I'm at work and can't download your part yet.
Are you using the Solid Sweep option to make the geometry?
https://help.autodesk.com/view/INVNTOR/2026/ENU/?guid=GUID-FCC0126F-50ED-449B-A0EF-1DED0287170B
Steve Walton
Inventor 2025
Vault Professional 2025
swlamech
I've been using the COIL option.  I only modeled the cylinder in there to show where the cutter would be.
SBix26
Solid Sweep was made for exactly this kind of task.  You model the cutter, and the path for the cutter to follow, and sweep/cut.  I've attached one way to accomplish this (Inventor 2024 format).  In this case I used Curve on Face in a 3D sketch to create the helical path, but there are several other ways to get there.
Sam B
swlamech
Thank You So Much !! I will give it a try !
