- Mute
- Permalink
- Report
Hello, I am trying to model a simple ramp cut into a piece of thick wall tubing. Essentially, this part will be held in a CNC lathe while a live spindle mill comes in perpendicular to tube axis and cuts while traversing in or out. When I try to create this with the coil command there's an additional angle to the surface and it's not perpendicular.
No matter what I do with the coil settings it doesn't work.
