Circular sheet metal pattern issue
JonnyPot
Message 1 of 8
JonnyPot
Hello everyone. i made a "circular" part like in the picture below and i want the number of folds to changes depending on the diameter.
Example:
I tried making it with a circular pattern in the sketch but when applying the Contour Flange it would only select the first line, if any one know how to fix this or has a better solution it would be greatly appreciated. Thanks in advance.
Accepted solutions (3)
Replies (7)
Message 2 of 8
spencer
That's typical behavior of the contour flange tool, where additions to the contour line aren't automatically added to the feature.
I would imagine you want to be able to get a flat pattern of the part, so that does complicate things a bit as far as what you can do. What might work is to make a contour flange of just the first 2 segments, then circular pattern the segments to where the first one of the 'new' is on top of the second one of the 'original', so that you still have bends between the parts. Though you'll need to do something like a direct edit to pull back the sides so they don't collide in the bends, then probably add 2 more small contour flanges to finish off the ends
About like so, but I can't make a full part at the moment to show what I mean
Message 3 of 8
jeremy_wasserstrass
One method I have used is lofted flange. The way I have used the lofted flange feature is to set the "facet length" to what I want for my bend spacing, then when I change the radius in the sketch it updates the number of facets. See the example I have attached(2022).
Using Inventor 2026 on Windows 11
Ideas needing support: spur gear tooth profile, rack gears generator
Message 4 of 8
JonnyPot
bouth solution are great, thank you very much
Message 5 of 8
SBix26
Here's a different way to tackle this one.  The attached file is Inventor 2022 format.
This creates one segment of the ring by calculating its parameters based on the desired segment length, then patterning the calculated number of times around the semi-circle.  All based on the diameter (d0 in this case).
You haven't given much in the way of detailed specifications, but this could be refined to dress up the ends a bit.
Sam B
Inventor Pro 2022.2.2 | Windows 10 Home 21H2
Message 6 of 8
JonnyPot
It's very good, i just have one question what the "ada" in the parameters stando for. Thank you
Message 7 of 8
SBix26
I have no idea.  That parameter is not in the file I have.
Sam B
Message 8 of 8
johnsonshiue
Hi! "ada" looks like the circumference of the circle.
Many thanks!
Software Test Engineer
