Circles in sketch are not round
jorisQUNSN
Message 1 of 10
jorisQUNSN
When i draw a cirlcle it's not displayed as a round circle. Does anybody know how to fix this?
Replies (9)
Message 2 of 10
JDMather
@jorisQUNSN
Can you Attach your file here that exhibits this behavior?
Is this a new issue, it used to work but now it doesn't? Or did it never work correctly?
What are your system specs - especially graphics card?
What version of Inventor are you running?
How far is your geometry from the Origin?
Why are the same dimensions repeated multiple times?
Is your Display Quality set to  Smooth, Medium or Rough?
Message 3 of 10
jorisQUNSN
Normally it works fine.
Processor 13th gen intel core i9-13900 2.00GHZ
32 GB ram
NVIDEA Geforce rtx 4080
i am using inventor 2023
Message 4 of 10
JDMather
@jorisQUNSN
A *.png file is not a *.ipt file?
I added additional questions to my original reply.
Message 5 of 10
jorisQUNSN
here the IPT file
Message 6 of 10
SBix26
The file you posted looks nothing like the images you posted:
One sketch containing four sketch blocks, all similar to what you see above.  Wrong file, perhaps?
Sam B
Inventor Pro 2024 | Windows 10 Home 22H2
Message 7 of 10
kacper.suchomski
This is most likely due to hardware/software performance. Your sketch is ~63 m; it's a lot. However, exact mathematical cylinders are created during the extrusion operation.
Kacper Suchomski
Message 8 of 10
SBix26
OK, I didn't zoom in far enough to see the circles!  And yes, it is very large for Inventor's math to work reliably, especially in graphics.
Sam B
Message 9 of 10
rhasell
Hi
Your sketches are too far away from zero.
The sketch1 it's self looks okay at 31m, but the problem lies with the blocks.
The Blocks are over a kilometer from zero.
Edit each block and move them closer to zero, this will fix your problem.
Reg
2026.3
Message 10 of 10
johnsonshiue
Hi! The problem is indeed with the distance between the origin and the block definition geometry. Edit the sketch block "deel1." Move the cursor to the geometry. You will see the coordinate reading on the lower right is extremely large.
I suggest you delete the Fixed constraints and move the sketch geometry closer to the origin. Then the circles will be circles.
Many thanks!
Software Test Engineer
