Changing Background color and visual style with iLogic
SveinnIngi
SveinnIngi
An Inventor file published an .jpeg image when running an iLogic Rule. Multible users with different templates are executing this but I want a uniform output.
This code at top of the rule was a game changer for me (Kudos to Curtis).
'Return view to Home view
ThisApplication.CommandManager.ControlDefinitions.Item _
("AppViewCubeHomeCmd").Execute
'zoom all
ThisApplication.ActiveView.Fit
 http://inventortrenches.blogspot.is/2012/01/autodesk-inventor-ilogic-sort-browser.html
-> I would also like to change Color scheme, Background and Visual Style within the same rule.
Is this possible?
Sveinn
mcgyvr
Some stuff here
https://forums.autodesk.com/t5/inventor-customization/ilogic-change-background-colour/td-p/5823608
SveinnIngi
Thank you for a super quick reply mcgyvr! This helped. I also found this stuff:
https://forums.autodesk.com/t5/inventor-customization/ilogic-code-for-visual-styles-shaded-with-edge...
...and ended up with this code:
Dim oView As View = ThisApplication.ActiveView
oView.DisplayMode = DisplayModeEnum.kShadedWithEdgesRendering
oView.Update
ThisApplication.ColorSchemes.Item("Presentation").Activate
ThisApplication.ColorSchemes.BackgroundType = 52737
'zoom all
ThisDoc.Document.SaveAs(ThisDoc.Path &"/" &MCode &"_" &ConveyorID & ".jpg" , True)
...Which works for me and I go happy into the weekend! Thank's.
yuvraj.dhinjal
I am a new user to Inventor. Is there any easy way to change the background color?
I have used NX before and it very easy to change the background color.
Curtis_W
Hi @yuvraj.dhinjal,
Welcome to the forum.
See this video for the basics of how to change the background color in Inventor.
Also here is a related link:
http://inventortrenches.blogspot.com/2012/09/inventor-background-color-as-white.html
Note that your question is a bit different from the original question of this discussion topic. Just for consideration in the future, please know that it is generally preferred that you start a new topic, rather than append your additional question to an existing topic, unless the topics are the same.
I hope this helps.
Curtis
