iLogic code for Visual styles - Shaded with edges
Does anyone know the script for it? Would like to have this script in my template for assemblies. So when user opens up the assembly it changes the visual style automatically.
Thanks in advance.
Alex.
Vladimir.Ananyev
When Inventor opens the document in visible mode it makes the document active and displays it in active view. At this momemt  you may change active view properties as desired.
Try the following rule:
Dim oView As View = ThisApplication.ActiveView
oView.DisplayMode = DisplayModeEnum.kShadedWithEdgesRendering
oView.Update
Then make this rule triggered by the event “After Open Document”.
Note that Inventor document object has the collection of views, so you may also change properties of View objects in the collection Document.Views.
DisplayModeEnum constants are discribed in the Inventor Programming Help:
kHiddenEdgeRendering, kIllustrationRendering, kMonochromeRendering,
kRealisticRendering, kShadedRendering, kShadedWithEdgesRendering, kShadedWithHiddenEdgesRendering, kWatercolorRendering, kWireframeNoHiddenEdges, kWireframeRendering, kWireframeWithHiddenEdgesRendering
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Thanks o lot!
