Run Macro On Save
Run Macro On Save
isocam
Run Macro On Save
isocam
The attached addin works Ok except that it only accepts "ipt" files.
Can anybody upgrade the addin and compile it so that it can accept "ipt", "iam" & "idw" files?
Many thanks in advance!!!
MegaJerk
For the people that do not have Visual Studios, perhaps you could explain what it is you're doing On Save. Perhaps it could be done via iLogic / API instead / Event Triggers instead?
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Ralf_Krieg
Hello
Open the StandardAddInServer.vb with an Texteditor, scroll down to the end and replace the OnSave-Sub with this:
Private Sub m_applicationEvents_OnSaveDocument(ByVal DocumentObject As Inventor._Document, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_applicationEvents.OnSaveDocument
            If BeforeOrAfter = EventTimingEnum.kBefore Then
                'Lets make sure that the active document is a part document
                If m_inventorApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                    Try
                        Dim invVBAProject As InventorVBAProject = m_inventorApplication.VBAProjects.Item(1)
                        Dim invModule As InventorVBAComponent = invVBAProject.InventorVBAComponents.Item("Module01")
                        Dim invSub As InventorVBAMember = invModule.InventorVBAMembers.Item("Main")
                        invSub.Execute()
                    Catch ex As Exception
                    End Try
                If m_inventorApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                    Try
                        invSub.Execute()
                    End Try
                If m_inventorApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
                    Try
                        invSub.Execute()
                    End Try
        End Sub
 EDIT: compiled dll attached (replace txt with dll)
R. Krieg
RKW Solutions
www.rkw-solutions.com
xiaodong_liang
Autodesk Support
Autodesk Support
I think krieg's code answers this question. If the code in each branch is same, I would suggest to combine all conditions, e.g.
DocumentTypeEnum docType = m_inventorApplication.ActiveDocument.DocumentType
If docType = DocumentTypeEnum.kPartDocumentObject Or
    docType = DocumentTypeEnum.kAssemblyDocumentObject Or
    docType = DocumentTypeEnum.kDrawingDocumentObject Then
