Change View Orientation & Rotate Angle
tmarrazzo
tmarrazzo
In Inventor 2013 when you would right click on a projected view of a part, the window that came up had a little cube you could click on and rotate the angle of view by a variable angle in all 3 planes. Inventor 2016 does not have that option to rotate the angle of view in my .idw. Is there a way I can rotate my view angle in 2016? I used to be able to do up my .idw and make my vie angle match previously drawn dws's in Autocad (these are catalog line drawings), and now I can't do that anymore. There has to be an easy answer, I can't imagine they would remove this option.
Tony
Replies (17)
mdavis22569
I'm not sure 100% what you are referring too ...
but I thinking this is what you might be referring too ...
If not please post an example from 2013
Mike Davis
tmarrazzo
The top one is the first screen you get when you right click on the view and choose edit view. The second one is the screen you get when you click the change view orientation icon that is what you see on the first shot. This allows you to choose the degrees of rotation and which plane you are rotating. That Icon is not on 2016.
JDMather
Changed in later releases.
http://help.autodesk.com/view/INVNTOR/2017/ENU/?guid=GUID-59C0094B-4B2D-4176-ABC0-A9FB8E311316
tmarrazzo
I went ahead and marked this as solved, but unfortunately I don't have the current release and my company isn't doing support so I don't think I can even get it - my release doesn't have the custom view available 😞 It looks like I have to rotate the drawing/assy view and not the .idw view?
TheCADWhisperer
@tmarrazzo wrote:
... - my release doesn't have the custom view available
I thought you said you were using r2016?
I just checked - and it is there?
tmarrazzo
JDMather
In Post #3 you are entering from the drawing environment, now in the latest image you are in the modeling environment.
I think you are getting the two view cubes mixed up.
Video to follow.
tmarrazzo
Nope, don't have a cube in my .idw's..........
JDMather
Can you attach a dummy *.ipt file and a dummy *.idw file here with one view of the part file?
tmarrazzo
Like this?
tmarrazzo
When I go to the View tab, and click on User Interface, the View Cube is grayed out?????
JDMather
What happens if you double click on your Base View (the one on the left side of the sheet.)?
(or right click on the Base View and select Edit View)
What happens if you start a new Base View on that sheet?
JDMather
tmarrazzo
Double clicking on the view did it, thank you!!!!!! I will play with it some more.
tmarrazzo
Not as fast and easy as 2013 but it gets the job done, thank you - you made my day - and Merry Christmas!
damjan_baraga
Hi
I have problem with rotation of views made with previous version (Inventor 2013).
Here is main view.
After double click on that view, I get this:
No possibility to turn this view.
If is view made in version 2019 or if is single, makes without problem, because it shows turning cube.Zajeta slika3.JPG
msmaneBESKZ
Community Visitor
Community Visitor
Thank you for the illustrative answer.
