How can I move files one folder up?
TomPrem92
TomPrem92
I've been using Inventor for some time, currently sitting at 2021 version. I'm not using Vault currently.
I usually move designs around using either Design Assistant or built-in iLogic Design Copy. However I've run into a problem from the topic title. I copied a design to a fresh project, but I wish to move some parts and subassemblies within the project one folder up. iLogic DC won't let me, cause it copies the folder structure up to 1 folder up from the subassembly being copied. Design Assistant is painful experience when there's more than a dozen parts. So what is the trick to move a sizeable portion of a design one folder up?
Kind regards,
Tom
TomPrem92
Nevermind.
DA wouldn't let me browse to new project location with batch patch change until I set the project correctly...Too bad I can't delete the post.
