Change selection color in IDW
Message 1 of 12
I have a vision weakness known as anomalous trichromatism of the deuteranomaly type.  This is more commonly known as color blindness with the green spectrum being affected.
I have a very hard time distinguishing selected vs not selected lines in IDWs. Is there any way to change the color of the selected lines? The default green is nearly impossible for me to distinguish from black...
I am confident with modifying the registry if necessary, as this doesn't seem to be a readily available feature.
Replies (11)
Message 2 of 12
mdavis22569
what do you have for a back drop are you not seeing the tan sheet, black lines that highlight red?
 ...my colors are black and red ...
Mike Davis
Message 3 of 12
This is the pre-highlighting. Which is with the mouse over the line but not selected.
This is the selected/highlighted line.
Here is where the real problem comes in. While sketching lines, the lines are already green and the selected line is almost indistinguishable from the non selected lines (to me).
See the line between the two 6.00" constraints is selected?
Message 4 of 12
mdavis22569
Try changing your color schemes under Options, Display ...
and see what one helps you see the dim's lines etc better
Mike Davis
Message 5 of 12
**EDIT**
It appears that the color schemes do change the color of the lines that are drawn. The highlighting appears to be static, however, with the different colored lines, I can now distinguish between the selected and not selected.
Thank you for your help!
**EDIT**
The color schemes don't change the color of lines in the IDW, only the background it seems. I made some screenshots to illustrate this between several different variations of the color schema.
Message 6 of 12
I would still like to change the highlighted/pre-highlighted color if at all possible.
Message 7 of 12
mdavis22569
Yes that's correct ....it changed the highlight colors ...
However You could make your own layers ..and edit the colors to what works best for you ....
Mike Davis
Message 8 of 12
salariua
There is a little utility called Color Scheme Editor. If you go to
C:\Users\Public\Documents\Autodesk\Inventor 2015\SDK\
and you install usertools.msi you will get a new folder UserTools and in there
C:\Users\Public\Documents\Autodesk\Inventor 2015\SDK\UserTools\ColorSchemeEditor\Bin
is this little utility that can help you make the changes.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 9 of 12
I would like to change colors as suggested. However, in inventor 2020, the folder ColorSchemeEditor was not included when installing the usertool.
Is there a way to change the colors now?
Message 10 of 12
SBix26
Sam B
Inventor Pro 2022.1 | Windows 10 Home 20H2
LinkedIn
Message 11 of 12
Hello
suggested solution only changes the background colors in drafting, and line/selection colors in design.
I would like to change in drafting mode, the color of the lines when highlighted and selected.
There is a way to change in document settings, but this only changes for the currently open document since it is documten setting. I would like it to be permanent application setting.
Br, David
Message 12 of 12
SBix26
Ah, I see.  This will need to be a proposal in the Inventor Ideas forum.
You could change the document settings for your drawing template(s), and perhaps even write some code to propagate that setting to all existing drawings, but other users may not appreciate that change.  It really should be a user setting, not a document setting.
If you create an Idea in that forum, please post a link to it here so that others can vote for it.  I would, for sure.
Sam B
LinkedIn
