Change parameters in user-template via irule
- Mute
- Permalink
- Report
I would like to create an iam-file as a template which already includes 3 part-files and a rule to change some of the parameters of the parts. This is working fine so far.
My problem is, whenever I change the parameters of a part via the rule it changes the parameter in all documents created with this template. If I change the parameter directly via the factory properties it only changes the part in the document. Is there a way, to change only the active iam-document using a rule?
I will give you a quick example: The height of a rack is changed via the factory properties. The rack is than adapted in the iam-file I am working on. I then designed a rule which sets the height of a ladder (a second part in the same iam-file) equal to the rack. When I run the rule it changes the height of every ladder in every open iam-file. I want both parameters to only change in one file, so I can use it as an adaptable template.
Thanks a lot for any help in advance,
Rijke
