Dimension Style Help needed!
Mark.Valenti
Mark.Valenti
I am trying to set the current dimension style to a custom format. Within the Dialog Box Style and Standard Editor the Standard exists and is Active, Under Dimension are various styles and the custom one I would like to use is listed. The problem I am having is on the Format Panel on the Annotate ribbon the Style pulldown is blank when I click the down arrow. no selections are possible. Help Please.
-Mark
-Mark
i7-7700K @4.2GHz
32 GB Ram
Nvidia Quadro 5000
ShayaGhanbar
The pull down is empty when there is no dimension in your drawing. As soon as you have a geometry with dimensions, the pull down will work.
Did you find this reply helpful?  If so, please use the Accept as Solution or Kudos button below.
Shaya Ghanbar, P.Eng.
Technical Specialist - MFG
SolidCAD - A Cansel Company
Have you selected or are you placing a dimension?
Can you post a screen shot?
kennyj
To follow up on ShayaGhan's correct response, you must have the dimension (or leader or other command) activated before the styles become visible/available.
Kenny
Mark.Valenti
What thru me was that I guess I cant get the custom dimension style to be the default... So once put a dimension on the drawing, then the styles became available. thank you for the help.
-Mark
i7-7700K @4.2GHz
32 GB Ram
Nvidia Quadro 5000
SBix26
Sure you can-- that's exactly what the Object Defaults style is for.  Edit your active Object Defaults style and apply your custom dimension style wherever it's appropriate (linear, radius, diameter, ordinate, etc).
Sam B
Inventor Professional 2017.4
Vault Workgroup 2017.0.3
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
