I am trying to make a bolted connection in Inventor 2023.
It works, but I would like to use a bolt a little longer than what Inventor gives.
Is there a way to force the length I want?
Or is it possible to set an offset for the location of the nut, so the length of the bolt gets longer?
Thank you in advance.
Solved by kacper.suchomski. Go to Solution.
Hi
You should see a length manipulator (arrow) in the graphics area.
Kacper Suchomski
This is a dialog box. The graphics area is the area of software where you see the three-dimensional model.
Kacper Suchomski
