Find all parts excluded from nesting via model browser, un-exclude programatically?
ccec_ireland
Message 1 of 21
ccec_ireland
Hi All!
I have several models which at one point in time or another have had certain parts excluded from nesting for various reasons. This was done by right click in model browser and select "exclude from nesting." Now, through part and assembly re-use in newer projects, I find myself constantly missing parts because the "exclude from nesting" property followed the part through the copy design operation into the new assembly.
I really don't want to have to manually look at every part to see if that property is set. I was hoping I could just use "Find Component" and search for those with that property set (this is how I find all invisible parts in an assembly) but I do not see that property available in the search parameters.
Does anyone know of a way to identify the parts which have been excluded from nesting? Or perhaps a bit of iLogic to iterate the model and clear that flag from every part?
Other ideas of ways to fix/work through this besides the obvious policy fix of "quit using the exclude from nesting flag"?
Thanks!
2025: AutoCAD, Inventor, Inventor Nesting, Vault Pro
Replies (20)
Message 2 of 21
A.Acheson
Hi @ccec_ireland
Can you send a screenshot of the command you need to use. I assume your using an addin? Can you share the name of that? I doubt there is API access to this exclude command but you might be able to fire the UI command when the correct browser node is selected effectively like pressing the UI Button.
Regards
Alan
Message 3 of 21
ccec_ireland
I do have a few plug ins, but I believe this is a standard feature. We are currently on 2022.
Message 4 of 21
A.Acheson
I believe this command button comes into use when the nesting add-in is used. I haven’t seen this before. You can check if the command button exists by checking the control definitions. From this post here
Run the code and then search the text file for keywords such as “Nesting”.
You should see a line which has exclude from nesting as a note. If you do then the control definition exists and you can execute it to mimic you pressing the button. The next step would be to highlight the part and press the button.
Regards
Alan
Message 5 of 21
ccec_ireland
@A.Acheson thanks for the ideas. I found these two sets of commands. Anyone familiar with these?
InventorComposites.MAGInvLaunchCmd.ExcludeFromNestingCmd +++ Exclude from Nesting.
InventorComposites.MAGInvLaunchCmd.UseForNestingCmd +++ Use for Nesting.
TRUNEST_COMMAND_EXCLUDEFROMNESTINGCMD_0 +++ Exclude from Nesting
TRUNEST_COMMAND_USEFORNESTINGCMD_0 +++ Use for Nesting
Message 6 of 21
A.Acheson
Good you found something. To run this when the part or browsernode is selected use the below. Type in the control definition you found into the brackets below .Item(".....')
If it switches it on/off then you have found the correct one. Selecting the occurrence/browser node is the next step after that.
    Dim controlDefs As ControlDefinitions = ThisApplication.CommandManager.ControlDefinitions
    Dim controlDef As ControlDefinition = controlDefs.Item(".....Enter Control Def......"
    controlDef.Execute
Regards
Alan
Message 7 of 21
ccec_ireland
These both compile and run, but so far I have not observed the state change when running these. I am selecting the part and then running the rule. Do I need to explicitly call the rule on the part from within the code? Thanks for the help, I'm brand new to iLogic.
Message 8 of 21
A.Acheson
So you can only change the setting by opening the part exclusively? If you can indicate what manual steps you take to change the setting then I can help you build around this information to automate.
Regards
Alan
Message 9 of 21
ccec_ireland
Correct. If I right click in the assembly tree, there is no "exclude" in the context menu. Even if I step into the part.
But if I open the part directly, I have the "exclude" option.
You can see in my context menu that "use for nesting" was the last command run. However, this doesn't clear the exclude check mark. If that's what it's supposed to do, and if this is how it is supposed to be used.
Is there no documentation from Autodesk on these commands and their use/syntax?
Message 10 of 21
A.Acheson
Ok then you need to be inside the part to run the rule. Alot of this is trial an error, narrowing down the correct definition to use. There is no help page other than to get to the definition list and how to execute. Can you attach the code your using?
Regards
Alan
Message 11 of 21
ccec_ireland
    Dim controlDef As ControlDefinition = controlDefs.Item("TRUNEST_COMMAND_USEFORNESTINGCMD_0")
    controlDef.Execute
I added this as a rule within the part, then selected the part and ran the rule. I tried it with all four commands, the exclude feature never toggled.
Message 12 of 21
ccec_ireland
Ok, I do have something working now. I thought these were both working, but in further testing only
is actually doing anything. This command will toggle that value regardless of where its currently set. In order to use this command, we will need to first check to see if the part is excluded or not.
Is there any way to get a list of the attributes/variables tied to a part? This bit must be stored somewhere and have a name.
Message 13 of 21
A.Acheson
Ah yes this is where having no API makes things very difficult.
From this article here
You can access the properties(iproperties) of the document.
  ' Get the active document.
    Dim doc As Document = ThisApplication.ActiveDocument
    ' Get the PropertySets object.
    Dim propSets As PropertySets= doc.PropertySets
    ' Get the design tracking property set.
    For each propSet As PropertySet = propSets
        For each prop As [Property] In propSet
        Logger.Info(prop.DisplayName)
        Logger.Info(prop.Value)
        Next
     Next
Regards
Alan
Message 14 of 21
ccec_ireland
I used this code to extract all of the property values from the file. I added some error handling because the images couldn't convert to strings, and output it to a file because I wasn't sure how to retrieve the logger info.
  'catch and skip errors
  On Error Resume Next
    ' Create empty list.
	Dim oList As New ArrayList
	oList.Add( "Property Name " & "Value" )
    For Each propSet As PropertySet In propSets
        For Each prop As [Property] In propSet
        oList.Add(prop.DisplayName & " = " & prop.Value)
        'Logger.Info(prop.DisplayName)
		'Logger.Info(prop.Value)
        Next
     Next
	'Create file.
	oWrite = System.IO.File.CreateText("C:\Temp\DocProperties.txt")
	'Write Array out to String.
	For Each Item As String In oList
		oWrite.WriteLine(Item)
	Next
	oWrite.Close()
I didn't see anything in there that appears to be related to the nesting status. Are there other property sets?
Message 15 of 21
ccec_ireland
C:\temp> fc DocPropertiesExcluded.txt DocPropertiesIncluded.txt
Comparing files DocPropertiesExcluded.txt and DOCPROPERTIESINCLUDED.TXT
FC: no differences encountered
Just to be sure I ran the rule with nesting enabled and disabled. Identical outputs.
Message 16 of 21
A.Acheson
One more thing you could try is to see if the Enabled status displays any difference if ticked or unticked. I suspect it will be the same because that usually just indicates if the button exists in the button dialogue.
Dim Ans As Boolean 'Check status of this command
Ans = controlDef.Enabled
MessageBox.Show(Ans)
@MjDeckdo you think there is away forward in detecting if the exclude from nesting is checked or unchecked? The command above simply Toggles it off and on with no way to detect the status.
Regards
Alan
Message 17 of 21
ccec_ireland
Yep, I get a TRUE either way.
Message 18 of 21
MjDeck
@ccec_ireland , there is an Attribute that you can read to get the exclude status of a part. It is on the Document object. The AttributeSet name is TruNEST_Attribute and the Attribute name is ExcludeFromNesting. It is an Integer. If the value of this Attribute is 1, then the part will be excluded from nesting. If the value is zero, it will be included.
You can use that to answer your first question: "Does anyone know of a way to identify the parts which have been excluded from nesting?"
Do you also want to implement this: "iterate the model and clear that flag from every part" ?
If so, I'll try to find out if it's safe to do that using only the Attributes API. That would be simpler than trying to run the command on individual parts.
Mike Deck
Software Developer
Autodesk, Inc.
Message 19 of 21
ccec_ireland
Thanks @MjDeck. I'll work on identifying the parts using that attribute. Even if I just end up with a list of parts to go in and manually switch, that's way better than having to manually search for them!
I would like to implement something to find and clear these flags through an entire model if I can. Please let me know what you find.
Message 20 of 21
MjDeck
I confirmed that it's safe to use the Attributes API to set the flag, rather than using the command. So if you want to clear the flags for all parts in an assembly:
  • iterate over all the parts
  • in any part where that Attribute is set to 1 (one), set it to 0 (zero)
Mike Deck
Software Developer
Autodesk, Inc.
