Inventor Forum
Change default to NOT show view scale?
10 REPLIES 10
Message 1 of 11
639 Views, 10 Replies
Is there any way to change the default so that the scale box is NOT checked when views are placed? (I have to turn this off every time.)
10 REPLIES 10
Message 2 of 11
No way to set defaults at this time.
Are you seeing this on base views? Base and projected views should not show
scale by default.
Andrew Faix
Product Designer - Inventor Drawing Manager
wrote in message news:5198806@discussion.autodesk.com...
scale by default.
Andrew Faix
Message 3 of 11
Come to think of it, I only see it on section views, detail views, etc...but I do a lot of those views, so it's just one more thing to do every time.
Message 4 of 11
I would like to see this as well Andrew...:)
Cory McConnell, AICE
www.mechanixdesigns.com
"Andrew Faix (Autodesk)" wrote in message
news:5198930@discussion.autodesk.com...
scale by default.
Andrew Faix
scale by default.
Andrew Faix
Message 5 of 11
So would I.
Andrew Faix
"Cory McConnell" wrote in message
news:5199242@discussion.autodesk.com...
scale by default.
Andrew Faix
So would I.
Andrew Faix
scale by default.
Andrew Faix
Message 6 of 11
news:5199261@discussion.autodesk.com...
So would I.
Andrew Faix
scale by default.
Andrew Faix
So would I.
Andrew Faix
scale by default.
Andrew Faix
Message 7 of 11
Andrew Faix (Autodesk) wrote:
> So would I.
I'd like to see the ability to set the view labels by template too.
For example, I always put "SECTION A-A", some people put "Section On
A-A", some just put "A-A"
We really really need the ability to customise this (and detail views
too) to user defined defaults.
And the ability to hide the scale by default too!
Rory
> So would I.
Rory
Message 8 of 11
Can someone tell me how you can set the Default of view labels so the visibility is toggled ON?
Message 9 of 11
deb.folz
deb.folz
Observer
Observer
Yes, this question was asked in 2006, but so far I too have been unable to find an answer. Anyone?? How can we eliminate the step of forever having to delete the SCALE??
And, is there a way to change the default of said section from Full to Distance?
Message 10 of 11
blandb
in reply to: deb.folz
blandb
It is in your drawing Styles manager. Manage Tab > Styles and Standards Panel > Styles Editor. Click on the active standard and on the right side, click on the View Preferences. Then Go to View Label Defaults. Using the drop down, choose the view you want to edit, then in the display to the right, just add or remove what you want.
As for the section, you can change the depth type upon placement:
Autodesk Certified Professional
Message 11 of 11
deb.folz
in reply to: blandb
deb.folz
Observer
Observer
Oh maaaaan, I just read your email
Yeah, now it works. (hitting my head on the desk!)
Thank YOU!!!!!
D
Thank YOU!!!!!
D
