Yes, this question was asked in 2006, but so far I too have been unable to find an answer. Anyone?? How can we eliminate the step of forever having to delete the SCALE??
And, is there a way to change the default of said section from Full to Distance?
It is in your drawing Styles manager. Manage Tab > Styles and Standards Panel > Styles Editor. Click on the active standard and on the right side, click on the View Preferences. Then Go to View Label Defaults. Using the drop down, choose the view you want to edit, then in the display to the right, just add or remove what you want.
As for the section, you can change the depth type upon placement:
