CHANGE CIRCLE DIMENSIONING FROM DIAMETER TO RADIUS BY DEFAULT
paulo_villarreal
paulo_villarreal
Hello
Does anyone know if there is a way to dimension a circle with a radius dimension by default? . Since it places a diameter dimension by default and I want a  radius dimension.
I have seen that it is possible to change the dimension with right click and dimension type, as in the following image, but I wanted it to place the radius dimension by default.
Greetings and thanks in advance
johnsonshiue
Hi! Unfortunately no, there is no option to set the default in 2D Sketch environment. A full circle defaults to diametric dimensions. An arc defaults to radial dimensions.
Many thanks!
Software Test Engineer
paulo_villarreal
Thank you !
