I am trying to create a die cutter which has 2 patterns, both patterns should have a 2.5mm chamfer in the outer side of the blade and a 4mm chamfer on the inner side. I was able to do the outer side but when I try to apply a 4mm chamfer on the inner edge an error pops up: The attempted Chamfer operation is too complicated to trim and joint to the part.
I can't mess with the shape of the pattern since we work on the micron scale.
Any ideas of how to solve this issue?
Thanks!!
Thanks!!
Solved by bob_holland. Go to Solution.
I would expect to see a bunch of Tangent constraints in your Sketch1, but I see only one Tangent.
I would also install the Updates.
@Anonymous ,
Welcome back to the Inventor Forum.
I have to agree with @TheCADWhisperer that tangential constraints are needed on your sketch:
I think that it is with these 6 lines but I would expect that if you are measuring down to the microns on this, you would want this sketch to be fully constrained.
Thank you and we hope to hear back from you soon.
@Anonymous ,
I Have added all the tangent constrains and now I can't do the chamfers or any side if the patter and also the measurements are a few mm off the drawing if I use tangent tool for the curve connections. Anybody knows how I can make the chamfer in this case?
Here is a video on where I think the issue is with your model.
Thank you.
Thank you.
Thank you!
will try to rework the shape to solve it
Thank you!
