Centerline question
Centerline question
anoor
Centerline question
anoor
Is there a way to add a center line to a radius? I.E.: Putting a center line thru a pipe elbow?Elbow Centerline.jpg
Mark.Lancaster
@anoor
No this is not possible (unless you sketch under that given view)..  You may want to check the Inventor Idea station for this idea and vote for it.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Mark Lancaster
jhackney1972
Yes there is, take a look at the attached screencast for the process.  In the screencast I only added the radius centerline but once the style is set, you can use it on straight sections as well.
John Hackney, Retired
Rory_M
Yes there is - Use centreline bisector and pick the inner and outer radii, see attached image.
Only issue is Inventor will extend the centreline slightly so you will see an overlap. Editing of the centreline style can minimise but not remove this altogether.cl.jpg
Mark.Lancaster
@anoor
My bad I was thinking of an auto-centerline from a routed system (piping) model..  And wasn't even thinking about what @jhackney1972 and @Rory_M have indicated to you.
Mark Lancaster
SBix26
Another possibility: if you have used a centerline sweep to model the part, you can include the path sketch in your drawing view.  If the geometry already exists in the model, you might as well use it.
Sam B
Inventor Pro 2019.1.1 | Windows 7 SP1
LinkedIn
