Inventor 2019 Export as .stl to print but is smooth does not have thread
devilinside128
Message 1 of 11
devilinside128
hello, I have inventor 2019 and office 2016 installed. when doing the thread it works, but when I export the object to print, in stl format. the object is smooth, it does not have the thread.
kelly.young has edited your subject line for clarity: The thread does not work
Replies (10)
Message 2 of 11
Mark.Lancaster
@devilinside128
How long have you been using Inventor?  Threads in Inventor are a cosmetic thread and there's no actual threads created.  So yes when you export it, its going to be a smooth surface..
Either model or use the cool orange thread add-in..  But when you start creating threads and more threads in your model its going to impact your Inventor performance.
Mark Lancaster
Message 3 of 11
mcgyvr
Ok.. Perfect... Inventor is working just fine then.. Smiley Very Happy
Try this and see how it works for you..
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=2540506896683021779&appLang=en&os=Win64
You may need to model the threads using a coiled sweep depending on if the coolorange tool produces "usable" threads with your printer..
Message 4 of 11
JDMather
http://autode.sk/1Gjao7K
http://autode.sk/1H3ryLe
kelly.young has embedded your screencasts for clarity.
Message 5 of 11
devilinside128
thank you very much, it works. another question. there is some plugin for inventor to export to gcode cnc
https://m.youtube.com/watch?v=iqnvzxuXFTQ
Message 6 of 11
JDMather
https://www.autodesk.com/products/hsm/overview?mktvar002=720092&mkwid=sFj3nM2aA|pcrid|231135701271|p...
Message 7 of 11
devilinside128
hello, thank you very much for the info.
last question. you know if there is a plugin for inventor, that does the same as the 123d make. my problem is that my pc is incompatible with that program
https://m.youtube.com/watch?v=0flRh9lrd9s
Message 8 of 11
TheCADWhisperer
I have never heard of "123d make".  Is this for professional use, or is it for hobby use?
What are your system specs?
Maybe Fusion 360?  Runs on  Windows or Mac but requires internet connection.
Message 9 of 11
Mark.Lancaster
@devilinside128
That product 123D has been discontinued and its features have been placed into Fusion 360 and another product which I can't remember.
Mark Lancaster
Message 10 of 11
devilinside128
fusion 360 if it works, but 1234d make is like an extension of the 360 ​​fusion, but it can work independent of the 360 ​​fusion. Apparently my graphic card is imcompatible. My machine is old, but it has been running these inventor programs 2019.
Message 11 of 11
devilinside128
Slicer for Fusion 360, 1234d.
123d make is the same, Slicer for Fusion 360. they just changed the name.
