CC shoulder screw error (part doesn't match description)
jyager
jyager
I have damper assy with approx. (75) 5/16 dia x 1"L shoulder screws holding damper blades to hinges.
The problem is the library has a gap between 3/4"L and 1"L...the thickness of materials was 7/8" (which is a readily available size...McMaster Carr...Fastenal, etc) and that's the length of shoulder CC inserted visually...appearing the correct fit, yet the CC data defaulted up to the next size in the table so they're all too long by 1/8"
Now we're stacking washers under the screw head to avoid dedicating new fasteners...is there a way to avoid this other than double checking everything the CC inserts?
Jason Yager
Inventor Professional 2025.0.1
Windows 10 Pro 21H2
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
32GB RAM
AMD Radeon Pro WX 3200 Series
3D Connexion SpaceMouse Pro
Mark.Lancaster
@jyager
It sounds like you are using the auto-drop feature of content center.  When you adjust the length, the increments are solely based on the length that are defined in Content Center.  So what look okay to you was the length that it selected.  It doesn't just pick random lengths..  It can only build off what it sees in the content center.
Mark Lancaster
jyager
Not sure how that makes it acceptable to have a 7/8" long shoulder show up with 1"L long shoulder table data?
Jason Yager
Windows 10 Pro 21H2
32GB RAM
