CANT FLATTEN THIS
CANT FLATTEN THIS
Message 1 of 17
CANT FLATTEN THIS
this is a very simple yet extremely important part that i need to flatten, and its driving me crazy, PLEASE HELP!
Accepted solutions (3)
Replies (16)
Message 2 of 17
jhackney1972
All I see is a couple of surfaces in your attached pictures.  Inventor must have a sheet metal body, with an applied sheet metal material (thickness), in order to make a flat pattern.  Please attach you model the next time you post so others can help you directly.  Pictures only give guidance.
John Hackney, Retired
Message 3 of 17
arron.craig
Although it's not the correct workflow and as jhackney1972 suggested, you should be using a sheet metal part do this. You can however use the new unwrap tool to get an approximate flat pattern of a surface.
Message 4 of 17
Yijiang.Cai
@Anonymous , which release you are using now? We provide the unwrap function in Inventor 2020, and it is definitely used to flat this surface.
If you are using the release before 2020, could you attach the model here? We could investigate whether we could re-create the model using sheet metal features, and flat it.
River Cai
Inventor Quality Assurance Team
Email: [email protected]
Message 5 of 17
S_May
Message 6 of 17
i couldnt attach the IPT part last night, so here it is in RAR,, thank you
Message 7 of 17
i use the Pro 2017, i attached the file in a reply, i would also want to know HOW will it be flattened? its already in sheet metal mm
Message 8 of 17
thank you for the effort but i am using Pro 2017
Message 9 of 17
S_May
Message 10 of 17
i tried that last night, i am getting this error
Message 11 of 17
Message 12 of 17
arron.craig
Try using a contour flange instead of a surface loft, modify offset direction as needed in the contour flange settings. Then trim the solid using the workplane you created and the "split" tool.
You should then be able to create the flat pattern.
Also be careful to fully constrain your sketches. Unconstrained sketches are not good practice.
Message 13 of 17
Yijiang.Cai
@Anonymous , I do not have Inventor 2017. And I create the script to create this model. You could take a look at the attachment. Hope it works for you.
River Cai
Message 14 of 17
dear this is not a solution because it is only projecting half of the shape.. i want to know what is wrong, i have a CURVE (part of a spherical shape) which i thicknessed already, why inventor is refusing to flatten it? i need to export the shape to a mill.. please help.. i did the same steps that @S_May have done, it didnt work, i got an error, why did it work for him and not work for me?
Message 15 of 17
S_May
hi @Anonymous
I'm doing a screencast 🙂
Message 17 of 17
Thank you sir... this is a beautiful solution..
