I downloaded a part that we use on a machine from the manufacturer but the .ipt file cannot be modified. The ribbon is grayed out and so is iProperties. I just need to update the iProperties to add the inventory number.
Solved by mflayler. Go to Solution.
marked read only in Windows?
placed into your library location?
did you download an actual ipt file?
Can you post the file?
Attached the file. I downloaded it originally as either as an .ipt or a zip file i dont remember.
This is a CADNEAS part, these are a little more special than a typical Inventor Library file. Think CC family template almost. You will not be able to modify this.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
The best you can hope for is to Derive this into another IPT, then break the link to the original. At that point you can assign iProperties to the file.
I never download vendor parts as .ipt files, even if given the choice. STEP or SAT for me, so it's a dumb solid. Then I can change iProperties, appearances, even do a little bit of direct editing if needed.
Sam B
Inventor Professional 2016 R3 SP2
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
